Everything posted by steel
Hej, enligt beräkningar har jag 9,9 graders Antidive, jämfört med 10,2 grader på C2:an. Det var konstigt, men då har jag inte verklig rideheight utan bara uppskattad på ritning. Hmmmm Mvh Pär AntiSquat var ju inte lika enkelt, Dvs upp eller ner rörelse i chassiet vid acceleration. ..........Hmm. Får repetera gymnasiematten. Mvh Pär
Hjubasen på mitt chassie är ca 80 mm kortare än C4:ans. Dessutom är motorn ca 150 mm längre bak, i förhållande till framaxeln, samt någon mm längre ner mot backen. Uppskattat om man tittar på bilderna och jämför borde då inte både antidive och antisquat mildras något i mitt chassie ? NEJ , FEL !!! Mvh Pär Hittade detta: :Anti and pro dive can soften the suspension over bumps..or make it harsher...look below for the reason (where I talk about quadrants). Also anti or pro dive always cause a caster change over suspension travel. Using a lot of anti dive is done indeed to keep the car from nose diving while using soft springs.The anti dive calculation is done by extrapolating lines through the cross shafts to the intersection point, then going from the tire contact point through this intersection point all the way to the back axle and comparing this height to the cg height. For a simplification you can view it as quadrants. If your intersection point is above ground to the rear of the front wheels you have anti dive, same for in front of the car below ground. In the other 2 quadrants it's pro dive. If the intersection is at ground level you have 0% anti dive, same as parallel shafts with no caster change.Parallel shafts have a disadvantage in the field of obstruction collision, if you ride over a bump you want the suspension to move backwards so it softens out the bump. If you have pro dive through an intersection point in front of the car the suspension moves against the obstruction, making it a lot harsher. Parallel shafts don't do anything, they don't dampen not increase this. I would prefer the 1st, a little anti dive to smoothen out this, not having too much caster gain and the involved influence on the camber curve (more caster gain -> effective kingpin height is shortened reducing the camber change, if you have the intersection point in front of the car caster is reduced, although this is not a common geometry....let's ignore it for that reason)What do you want? Stiff springs or something a bit more comfortable? I'd stick with at least some anti dive, maybe 5% or so, not much more because of the caster effect. However, this is complex stuff and ride height, wheel diameter, center of gravity..it all has an influence. you will need some real accurate measurements to be able to do the calculations to a degree of accuracy to have any meaning. I would advise to stick with the stock C4 mounting relations. The mustang II front end, I know a lot of people use it but for a high speed car...it would not be my choice because of the short control arms and other short comings all resulting in a reduced high speed stability. The corvette engineers didn't use those long lower control arms for nothing, or the caster setup..and so on. They really did know what they were doing. The C4 front suspension is a fine suspension as is. If there's an area that can use some improving there it's the rear suspension, pre 87 jacking probs (too high roll center) and you can improve the toe control on it. Fick svar från Kulle att det finns Cobror med orginal infästning och utan. Han använder det inte på sin för att han tycker inte det behövs. Caster ändras vid infjädring med orginal. Kan inte svara vad som är bäst. Vi tackar dock för svar !! Tack Mvh Pär Mitt första antagande att vinklarna mildras är fel, det blir tvärt om. Återkommer med beräkningar.
Brutus är såld till en glad bilbyggare, Axel, från Halmstad. Han och en kompis , även han bilbyggare Bokchassie med R1, hämtade Brutus idag 53 mil enkel resa. Hoppas att de lägger upp varsin tråd. Mvh Pär Lite tråkigt var det allt, Widell.
steel replied to cealm's topic in Våra Locost 7/Seven Bilar
Grattis ! Milstolpe avklarad. Bara massa arbete kvar då Snygga bakljus ! Mvh Pär -
Okidoki Pac, detta är väldigt intressant ! Mäter och återkommer. Har varit på Julbord med jobbet, mao mäter inte idag . Kul att grotta i detta Mvh Pär
Jaha, så här ser det ut på C4:an. Säger inte mig någonting ? Mvh Pär
Det blir hur snyggt som helst. Mvh Pär
Har krånglat med pedalstället idag. Sänkt ner infästningarna och stagat upp. Bromsen blev bra. Däremot är kopplingen lite svår då man inte vet vilken hävarm det är orginal. Har provat mig fram och förlängt hävarmen bit för bit och kortat pedalen motsvarande. Tror jag hittat en medelväg med pedalrörelse kontra benmuskler. Riktigt hur det blir vet man ju inte förrän provkörning. Tror jag får göra ett skruvbart fäste ifall att det måste byggas om. Borde begärt att pedalstället skulle följa med motorn. Brutus kommer att hamna i Halmstad som det verkar. Mvh Pär
Låter bra med ledighet, då får man lite distans till saker och ting. Gäller att hitta en bra balans så man mår bra. Ha det gott ! Mvh Pär
Ta och se över ditt liv och fokusera på det som är viktigt Mvh Pär
Aj då, Pac ! Trodde jag skulle få enkla och tydliga instruktioner av dig om hur jag skulle fästa övre a-armen Vi får plugga på. Axly, den här fasen av byggandet är absolut den roligaste när saker och ting ramlar på plats, du får kavla upp ärmarna och dra igång. Mvh Pär
Axly, motorn är bara 730 mm bred vid kåporna SFRO , Ridderstolpe , var här på besök idag och inspekterade bygget. Mycket trevligt ! Fick tips på hur jag skulle fortsätta men i det stora hela tyckte han att det såg bra ut. Vi kommer att besikta bilen som sportbil (20 kw/ 100 kg !!) iom att det är C4 hjulupphängningar och rejält triangulerat/dimensionerat. Måste ha katalysatorer och värmepaket samt uppfylla avgasnormerna. 193 kW ger då ca 965 kg. Motor 227 kg+låda 60 kg+ tank 80 lit ca 75 kg+ batteri 15 kg+ förare 75 kg = 452 kg = 513 kg kvar att fylla upp, inte omöjligt tom utan minröjarplåt. Mvh Pär
Pac, du har helt klart en väldigt stor poäng i vad du skriver om att det blir en helt annan fordonsdynamik i mitt bygge jämfört med C4:an. Jag har inte grävt ner mig i denna frågeställning förutom det jag skrivit i första svaret. Kanske dags att göra det nu innan allt är helsvetsat, sedan är motståndet att ändra på något avsevärt högre . Hur mycket har du lärt dig ??? Mvh Pär
Hej, Pac ! Det där med antidive hade jag en del funderingar kring. Infästningen är C4 orginal och surfar man runt lite ser man att de flesta conversions de gör i USA med C4 hjulupphängningar i äldre bilar använder de orginal infästning likt den jag har, lite lätt lutad bakåt. Läste någonstans att GMs ingenjörer arbetat i flera år med C4 :ans hjulupphängningar för att de skulle bli optimala. Tittar man på Kulles Cobrachassi, som använder C4:ans hjulupphängningar, där har han rätat upp övre a-armen så den ligger vågrät. Hittade dock ingen information varför han/man gör så, valde därför att gå på orginal. Finemang, hittade oljefilterflyttare beställt ! Mvh Pär
Projekt till salu enligt tråd. Det som följer med : Chassie, hjulupphängningar, spindlar, bakaxel 1041 ( slungdiff ) , motor, låda , kardan. Motor ej 100 % komplett samt blåst topplockspackning. Det som INTE följer med: styrväxel, tank, rattstång och coilovers. Rattväxel som passar, 50 mm kortad Escort med 120 mm förlängare. Noll bumpster. 25 000 kr Mvh Pär
Tack, bara på med lite Sabaton, Corroded och Sparzanza i hörlurarna, sedan ger tempot sig själv Designen kommer från min feminina sida. Fick tag på Kapten idag, han hade navigerat fel !!! Var i Holland med båten. Kommer att tulla in axlarna den 3:e januari i Göteborgs hamn. Hmm...nästan abstinens. Hm.... Hm... Pär
Det där finliret är nästan det roligaste, men vid varje moment längtar man till nästa. Väldigt häftigt bygge, ser fram emot din avgjutning och karosspåbygge. Mvh Pär
Hej, har ev ett till salu. Kolla " Brutus T4 " Mvh Pär
Hej, enligt BOE, gammal känd bilbyggare, ska den övre vara 30 % kortare. Titta på bifogade PDF:er. A_armar_mall.pdf Tänk på att verkliga avståndet påverkas utav vilka leder du använder. Mvh Pär
Kul, Christer !! Jag har en diffad och en odiffad Sierra/ Scorpio diffklump över för billig penning. Snart klar med mitt chassie, bra terapi. Mvh Pär
Har efter mycket funderande beslutat mig att sälja projektet. Roligare med egenproducerat chassie. Annons kommer under säljes inom kort med vad som ingår osv. Mvh Pär
Doggers Bankar passerade Axly, hoppas denna skiss ger dig ytterligare inspiration: Super V8 ps.pdf Ca mått 1100 mm hög, 1900 mm bred och 3300 mm lång. Funderar på att kladda ihop nån plugg till bakdelen och gjuta själv. 80 liters tank och kylare beställda. Svetsat lite mer på chassiet. Bilder kommer senare. Mvh Pär
Menar du inte första 24 sekundrarna i första filmen ?? Hon med gula byxor verkade vara i fokus..... Mvh Pär
8 hjuling finns redan det med, Argo liten skogsmaskin, måste till fler axlar. Axly, intressant. Hoppas du får inspiration. Har letat efter lämplig kaross men ramlar hela tiden tillbaka på Sjua pga enkelheten och friheten. Inspiration kommer f.n. från den här : Kommer att lyfta upp karosslinjen ( för att få plats med motorn ) utan att höja bågen så den blir lite stabbigare. Kommer dessutom att trycka ut den lite bakåt för att få plats med STOR tank och STORT batteri. I värsta fall får jag släpa fram den beryktade minröjarbukplåten. Klappträ är ett väldigt bra uttryck väldigt enkelt att förstå att det inte är speciellt bra. Motorn dominerar, satte dit stolarna idag och de såg bra fjuttiga ut. Men det blir bättre när chassiet byggs upp. Kapten trycker bara på upptaget, förstår inte min iver, vet inte vart han befinner sig. Ville ha en modern V8 med potential. LS är uteslutet då minsta effekten i Sverige med alublock är 325 hkr. Förvisso är detta gjutjärn med , ville egentligen ha fatt på en tidig 4,6 SOCH med 140-160 kW men det blev den här efter diskussion med SFRO. Men sedan att det förb. filtret satt där, får jag ju skylla mig själv över. Åker f.ö. 350 Freeride. Får ta en dosborr. Micklade med båge idag, har alltid velat att huvudbågen ska gå ända ner till botten, nu gör den det. Mvh Pär
