steel Posted March 28, 2019 Posted March 28, 2019 Hej, nytt projekt! Beskrivning kommer. Mvh PÀr Quote
sorin Posted March 28, 2019 Posted March 28, 2019 Var tvungen att googla " Rockcrawler " . VĂ€ntar med spĂ€nning đ đ // Sorin 1 Quote
bexander Posted March 29, 2019 Posted March 29, 2019 Hm, ser ut som en ThrigeTitan-motor. Behöver du en till? Jag har en nyrenoverad 12kW liggandes... Quote
steel Posted March 29, 2019 Author Posted March 29, 2019 Hej, FIAT ??? Nej, LUPUS, ser inte riktigt var den skulle passa in đ Ăr intresserad, bexander, GrĂ„ben ska elektrifieras vad det lider. Bild pĂ„ GrĂ„ben, sitter en trilskandes WV motor med automat dĂ€r idag.  Mvh PĂ€r Quote
LUPUS Posted March 29, 2019 Posted March 29, 2019 troligen blir det aldrig byggt nÄgot pÄ den ÀndÄ, har ju gÄtt nissan spÄret nu , bÀttre om nÄgon kan anvÀnda den Quote
steel Posted March 29, 2019 Author Posted March 29, 2019 Ok,LUPUS, trodde du behagade att skĂ€mta med mig. Den var vĂ€l dessutom fossilđŁ Mvh PĂ€r Quote
LUPUS Posted March 29, 2019 Posted March 29, 2019 1 timme sedan, steel sade: Ok,LUPUS, trodde du behagade att skĂ€mta med mig. Den var vĂ€l dessutom fossilđŁ Mvh PĂ€r NĂ€ mest om du inte hade motor sĂ„ kan du fĂ„ tillbaka "din" med lĂ„da , svetsa diffen sĂ„ Ă€r det ju crawler Quote
steel Posted March 29, 2019 Author Posted March 29, 2019 Jaa, du menar Ansaldon, hmmm.... Mvh PÀr Quote
steel Posted April 1, 2019 Author Posted April 1, 2019 Hej, orkade inte skriva, gjorde en liten film istÀllet. Mvh PÀr 2 Quote
Offroad Posted April 2, 2019 Posted April 2, 2019 Detta ser kul ut, eller Ă€r du bara skojfrisk.đ 1 Quote
steel Posted April 2, 2019 Author Posted April 2, 2019 He, he Offroad ! BĂ„de och đ Mvh PĂ€r 1 Quote
Rikard Larsson Posted April 3, 2019 Posted April 3, 2019 Kan bli riktigt kul detta đ Och till Offroad: Vi som "kĂ€nner" Steel höjer nog inte ens pĂ„ ögonbrynen. SĂ„ att detta skulle vara en aprilskĂ€mt, nÀÀÀÀ. 1 Quote
Offroad Posted April 3, 2019 Posted April 3, 2019 Att kunnandet finns betvivlar jag inte efter att ha lÀs div trÄdar, men datumet. Offroad fordon Àr ofta hybrider i nÄgon mening. FosilbrÀnsle tills man inte kommer lÀngre dÄ drar man ut snöret pÄ elvinchen. 1 Quote
steel Posted April 4, 2019 Author Posted April 4, 2019 (edited) Hej, har nu varit lite intensiv Ă€ven med mina mĂ„tt mĂ€tt đ„ @Offroad , el Ă€r alldeles utmĂ€rkt för terrĂ€ngkörning. Fullt moment direkt !! Kommer att ha 15 kWh, rĂ€cker för flera timmars crawlande đ Mvh PĂ€r Edited April 4, 2019 by steel La till 2 Quote
LUPUS Posted April 4, 2019 Posted April 4, 2019 (edited) PĂ„ den tiden hann jag bara köpa dĂ€ck och bestĂ€lla stĂ„l rör đ.  För lĂ„ngsam .... vilken fördelnings lĂ„da blev det ?Ă€r det ladan som Ă€r rengjord ?  Ser relativt ny  ut .... Edited April 4, 2019 by LUPUS Quote
steel Posted April 4, 2019 Author Posted April 4, 2019 đLUPUS ! Det blev Lada Niva lĂ„dan. SjĂ€lva layouten pĂ„ ingĂ„ende axel i förhĂ„llande till utgĂ„ende axlar till kardanaxlana gjorde att det blev mycket lĂ€ttare att ansluta elmotorn. Fick dessutom lĂ€gre utvĂ€xling pĂ„ lĂ„g jĂ€mfört med valp vĂ€ndarlĂ„dan samt högvĂ€xel för transport och 2 och 4 hjulsdrift ! Mvh PĂ€r 2 Quote
steel Posted April 6, 2019 Author Posted April 6, 2019 PeerO@ đInte helt frĂ€mmande, har börjat flyga FPV med min son, vĂ€ldigt kul för övrigt, och sonen har vĂ€drat intresse för nĂ„got liknande. Dock, troligen pga Ă„lder, ser jag vissa risker med liknade flygdon. Choppad av propeller Ă€r en av dem.... Mvh PĂ€r Quote
steel Posted April 6, 2019 Author Posted April 6, 2019 Hej, bygger vidare, vĂ€ldigt kul đ Mvh PĂ€r 2 Quote
steel Posted April 10, 2019 Author Posted April 10, 2019 Hej, Àr det nÄgon som kÀnner igen dessa bromsok, mÀrkta med " Warburg" Sitter fram pÄ de konverterade Valpaxlarna. BelÀggen slut och oken troligen bortom all rÀddning. Mvh PÀr Quote
steel Posted April 11, 2019 Author Posted April 11, 2019 Hej, dags för en liten filmsnutt igen !!  Mvh PÀr Quote
LUPUS Posted April 11, 2019 Posted April 11, 2019 (edited) för det första sÄ tror jag du slog nytt rekord i byggande igen , men det börjar bli trÄkigt att pÄpeka det nu :-)   för det andra , har du hittat nÄgon fin step down DC/DC typ 380 volt till 12 ?`  duger med ganska lÄg effekt , bara underhÄlls ladda 12v sidan under drift Edited April 11, 2019 by LUPUS 1 Quote
steel Posted April 11, 2019 Author Posted April 11, 2019 (edited) Tack, LUPUS  Blir ju lite sport att öka tempot..... Hittade DC-DC nÄnstans pÄ nÀtet......men vart ?? Ska kolla Äterkommer.  Mvh PÀr Edited April 11, 2019 by steel Quote
bexander Posted April 12, 2019 Posted April 12, 2019 @LUPUS MÄnga nÀtaggregat som har PFC (Power Factor Correction) gÄr att mata med DC, se ex hÀr. De finns i mÄnga olika utspÀnningar och uteffekter, dock bör de sitta inomhus i bilen dÄ de sÀllan Àr vattentÀta. Quote
LUPUS Posted April 12, 2019 Posted April 12, 2019 (edited) 9 timmar sedan, bexander sade: @LUPUS MÄnga nÀtaggregat som har PFC (Power Factor Correction) gÄr att mata med DC, se ex hÀr. De finns i mÄnga olika utspÀnningar och uteffekter, dock bör de sitta inomhus i bilen dÄ de sÀllan Àr vattentÀta. inte ens tÀnkt i de banorna....!   kanske till och med ligger nÄgot och skrÀpar hemma .   Behöver man reglera en sÄdan eller Àr det ok att konstant köra den pÄ 12v ?  borde vÀl enbart lÀgga ut effekt om orginal batteriet sjunker under 12v ? Grund förutsÀttningen Àr ju att det lilla bly batteriet Àr fullt och sedan tar denna vid om det behövs , det Àr ju inte full laddfunktion utan mer slast support.   Edited April 12, 2019 by LUPUS Quote
bexander Posted April 12, 2019 Posted April 12, 2019 1 timme sedan, LUPUS sade: inte ens tÀnk i de banorna....!   kanske till och med ligger nÄgot och skrÀpar hemma .   Behöver man reglera en sÄdan eller Àr det ok att konstant köra den pÄ 12v ?  borde vÀl enbart lÀgga ut effekt om orginal batteriet sjunker under 12v ? Grund förutsÀttningen Àr ju att det lilla bly batteriet Àr fullt och sedan tar denna vid om det behövs , det Àr ju inte full laddfunktion utan mer slast support.   Det bÀsta Àr att ha ett 13,5-13,8V nÀtagg, annars blir inte 12V batteriet laddat nÄgot vidare. Tanken Àr att 12V batteriet enbart skall hjÀlpa till vid belastningstoppar som ex start av vindrutetrokare annars Àr det DC/DC som skall sköta resten. Vissa nÀtaggregat ger 13,8V frÄn början andra kan gÄ att justera upp frÄn 12V eller ner frÄn 15V, allt beroende pÄ specen pÄ det specifika agget. Quote
LUPUS Posted April 12, 2019 Posted April 12, 2019 risken Àr vÀl att man överladdar om man inte har förbrukare ?   hmm nÀsta steg vore ju nÄgot liknade man slÄr pÄ duty via en aurdino nu kapar vi fel trÄd oxÄ :-)  Quote
Rikard Larsson Posted April 12, 2019 Posted April 12, 2019 Du kan inte överladda om du stÀller det pÄ 13,8 V. Quote
steel Posted April 18, 2019 Author Posted April 18, 2019 Hej, liten provkörning utan bromsar och fel coilovers. 20190418_113013.mp4 4 Quote
steel Posted April 26, 2019 Author Posted April 26, 2019 Hej, jaha och hur tĂ€nkte jag hĂ€r ??? Blir vĂ€ldigt svĂ„rt att fĂ„ dit fĂ€lgen...... Gör om gör rĂ€tt đ Mvh PĂ€r Quote
steel Posted April 26, 2019 Author Posted April 26, 2019 Hej, nu blev det rÀtt. BMW E39 bakre bromsok. Mvh PÀr Quote
steel Posted May 6, 2019 Author Posted May 6, 2019 Hej, har klÀmt dit nÄgra aluminium plÄtar. Plockar f.n. med det beryktade Tesla modul batteripacket som blev övergivet i Fox Relliant trÄden, undrar hur det gÄr denna gÄng....??? Mvh PÀr 1 Quote
steel Posted May 12, 2019 Author Posted May 12, 2019 Hej, all aluminium pĂ„ plats : Och nej, jag och Tesla grejerna Ă€r inte kompisar.....eldade upp ett BMS för 3tkr đŁ 750 A Ă€r mycket krĂ€m nĂ€r det blir fel. Har bestĂ€llt ett nytt....tror ( skriver tror ) jag vet vad som blev fel. Coilovers kommer imorgon, dags för seriös provkörning. Mvh PĂ€r 3 Quote
bexander Posted May 13, 2019 Posted May 13, 2019 GÄr BMS:et att laga eller blev det fullstÀndigt popcorn? Quote
steel Posted May 13, 2019 Author Posted May 13, 2019 Hej, bexander ! TyvÀrr bara popcorn, kopplade ur strömförsörjningen, vÀnde mig bort och lÀste manualen med radiokÄporna pÄ. Funderade efter en stund vad det var som bubblade.....full rökutveckling, fick evakuera garaget. Suck ! Troligen jordningsfel i övergÄngen mellan kablagen i BMS:et. 6s i varje Teslamodul och 8s per kablage i BMS:et och för varje pÄbörjad 8 serie ska en jordkabel med. Blev nÄtt fel.  Mvh PÀr Quote
Kjelland28 Posted May 13, 2019 Posted May 13, 2019 JÀkla snyggt bygge ! Vad var det för axlar du anvÀnde ? Quote
steel Posted May 14, 2019 Author Posted May 14, 2019 Tack, Kjell ! Det Àr Volvo Valp axlar som Àr slivbromskonverterade.  Ny film pÄ byggnation och testkörning: Mvh PÀr 4 Quote
steel Posted May 26, 2019 Author Posted May 26, 2019 Hej, sÄ hÀr gÄr det nÀr man gör bypass pÄ discharge funktionen om man har ett för litet BMS och inte hÄller koll pÄ spÀnningsnivÄerna. Kunde iaf rÀdda hÀlften av cellerna..... Mvh PÀr 2 Quote
LUPUS Posted May 27, 2019 Posted May 27, 2019 Kör sĂ„ det ryker borde inte vara en term man anvĂ€nder pĂ„ elbilar đ .  Vad gick fel i detalj  ? Quote
steel Posted May 27, 2019 Author Posted May 27, 2019 Nja, inge bra pÄ elbilar ifall det inte gÀller dÀcken. Felet var att BMS:et slog ifrÄn vid provkörningen dÄ motorn drog momentant mer Àn 200 A som var limiten pÄ BMS:et. Batterierna klarar 400 A sÄ smarte PÀr kopplade sonika bort discharge frÄn BMS:et och satte direkt pÄ minuspolen istÀllet. Charge fick vara kvar. I provkörningsivern nÀr de nya coiloversen kom pÄ plats hade nÀmnda PÀr inte koll pÄ att nÄn cell hamnade under vad som Àr lÀmpligt spÀnningsmÀssigt och viss rökutveckling uppstod. Cell överbelastad. Knuffade hem ekipaget och laddade upp pÄ nytt, inget konstigt vid laddning och trodde att allt var ok. Men icke, en cell var förstörd och vid nÀsta körning tog det eld. LÀrdom: se för f..n till att ha rÀtt BMS !!  Mvh PÀr Quote
steel Posted June 11, 2019 Author Posted June 11, 2019 Hej, bygge av Tesla 48 V batteripack :Â Â Â Mvh PĂ€r 2 Quote
Jocke4U Posted June 12, 2019 Posted June 12, 2019 Snyggt! Kanske du skulle ha ett nytt forumnamn sĂ„som "ElÂŽGeek" đ đ 2 Quote
steel Posted June 18, 2019 Author Posted June 18, 2019 Hej, lite mer om batteribrand : Â Mvh PĂ€r Quote
steel Posted September 21, 2020 Author Posted September 21, 2020 Hej, ny drivenhet. 4 X mer kW och 70 kg lÀttare..... Konstant AWD dock. Mvh PÀr 2 Quote
Kjelland28 Posted September 22, 2020 Posted September 22, 2020 Halloj ! Har en bekant som Ă€r insatsledare pĂ„ brandkĂ„ren, han sĂ€ger att sĂ„na dĂ€r brinnande batterier ska man hĂ„lla sig lĂ„ngt ifrĂ„n för dom ger ifrĂ„n sig giftigheter som gĂ„r igenom alla deras skyddsklĂ€der. sĂ„ ta det försiktigt nĂ€r du eldar batterier đ   Quote
steel Posted September 22, 2020 Author Posted September 22, 2020 (edited) Tack, Kjell för omtanken ! Har förstÄtt att det inte alls Àr bra. I Tyskland har de sonika en hel container med lÀmpligt brandslÀkningsmedel dÀr de sÀnker ner elbilar ifall de tar eld. Har svetsat klart subframen för drivenheten. Fick Àven dit nÄgra rör under för att skydda drev och motorfÀste. Punktade dit den med hjÀlp av en plÄtbit  och telfer. Mvh PÀr Edited September 22, 2020 by steel Quote
steel Posted September 23, 2020 Author Posted September 23, 2020 Hej, fÀrdigsvetsad subframe och provmontage av motor och transmission. Mvh PÀr Quote
steel Posted September 26, 2020 Author Posted September 26, 2020 (edited) Hej, fick till batterilÄdan dÀr BMW I3 modulerna ska vara. PÄ sista bilden syns en liten förstÀrkning av k-lÀnken. Den hade blivit lite krokig. Mvh PÀr Edited September 26, 2020 by steel Quote
steel Posted September 28, 2020 Author Posted September 28, 2020 Hej, provmontage av I3 modul i batterilÄda. Div fÀsten ditsvetsade. Mvh PÀr Quote
