Hello everyone,
Sorry to post this in English in this section.
Does anyone know a company in Sweden which manufactures custom propshaft, just as Bailey Morris (http://www.baileymorris.co.uk/kitcar.asp) does in the UK?
My local engineering shop don't want to shorten the one I have from my donor, so I guess I'll have to buy a custom made one :(/>
I live in Kronoberg, close to Växjö. I'm building a Haynes Roadster with 2.0i DOHC engine and a MT75 gearbox from a Ford Sierra 2.0i CLX 1992.
Thank you very much in advance for your replies.
Sylvain
There is a company called Svea Kardan in Stockholm but they are usually quite busy.
A lot of Swedes buy from UK, Northwest Propshafts or Dunning and Fairbank for example. In many cases it works just as well.
You might be lucky and find someone local that knows of a company that will shorten your donor prop too.
Regards
Gustaf
Thank you very much for the reply Gustaf, very helpful.
I've contacted Svea Kardan in Bromma, we'll see if they reply.
Otherwise I guess I will have to order it from the UK, I've sent enquiries to 3 different companies, so we'll see...
I'll post the result of my researches here when I get all the answers.
Thanks again.
Best regards.
Sylvain
Svea kardan is very expensive. I send up material to them and i wait months and it costs 4300sek (year 2009).
It is about £ 409.
I used a small company in Kimstad in the vincinity of Linköping. They shorted and balanced my propshaft. The price was very different from Svea Kardan :-).
I think it was:
Kimstad Bilservice
Per Larsson Reparationer
011-53224
Don't know if they are still there though.
/Peter
Northwest Propshaft is recommended. Half price compared to Sweden and all new parts. You will have it in less than two days. Mine took 26 hours from order until i had it in my hand.
£ 183.30 in 2010.
Har skickat förfrågan till dem nu.. 20:00 får se hur snabbt de svarar.
Hi Richard
Thank you for your email.
This is what we can do for you.
Build Spec.
Shaft1
Gearbox Flange : 1140 Series
Reverse Box: 1140 Series
UJs: Standard Universal joints
Length: 510mm Gearbox Flange to Reverse Box
Price: £98 + VAT
Shaft 2
Axle flange : 109mm Dia, 90mm PCD, 56mm Male register
Length: 710mm Reverse Boxl to Axle Flange
Price: £98 + VAT
Delivery Options
Option 1
TNT Economy 3-5 Days Sweden £45 + VAT
Option 2
TNT/DHL 1-2 Days Sweden £60 + VAT
Ja det är svårslaget :D
Sen är det intressanta att tiden som fraktbolaget tar inkluderar tillverkning av din unika beställning :lol: :prop: Luktade nymålat när man packade upp den :)
Northwest Propshaft är dom bästa jag har gjort affärer med alla kategorier!
Jag valde TNT ekonomi då det inte var så bråttom, men den kom dagen efter ändå kl 13 med Posten.
Då var två nya axlar uthämtade från Posten.
Beställde vid middagstid förra tisdagen, fick svar på tio minuter att jag skulle maila mitt telefon nummer så de kunde ringa när delarna var klara att skicka.
kl 13:00 onsdag fick jag samtalet och vi gjorde upp betalningen. Valde ekonomileverans snål som man är, men kunde hämta paketet i Skellefteå i Tisdags. Jag är klart imponerad.
Dessutom var det rätt grejer och allt passade bra :thumbsup:
Tror ni jag kan beställa en kardan från Northwest Propshafts med Volvo medbringare i båda ändar? Till min 6-hjuling som är förlängd kan jag inte använda en vanlig omsvetsad Volvokardan. Den blir för kort.
