Coolt, eftersom jag hade alla delar lösa (mer eller mindre) så höftade jag fram lite mått + tog dom som fanns i Haynes Roadster boken och matade in dom.
Resultatet finns på denna länken. http://vsusp.com/#0.8%26project_name%3AHaynes Roadster%26trim{body_roll_angle%3A0|front.left_bump%3A0|rear.left_bump%3A0|front.right_bump%3A0|rear.right_bump%3A0}%26front{frame.susp_type%3A0|frame.bottom_y%3A12000|frame.center_to_upper_mount_x%3A33500|frame.bottom_to_upper_mount_y%3A23700|frame.center_to_lower_mount_x%3A24700|frame.bottom_to_lower_mount_y%3A5500|control_arms.upper_length%3A28800|control_arms.lower_length%3A41500|knuckles.hub_to_upper_x%3A14300|knuckles.hub_to_lower_x%3A9800|knuckles.hub_to_lower_y%3A10000|knuckles.hub_to_upper_y%3A12500|knuckles.hub_to_strut_axis%3A14000|knuckles.strut_incl%3A8000|steering.active%3A0|steering.hub_to_outer_tie_rod_x%3A8000|steering.hub_to_outer_tie_rod_y%3A4300|wheels.offset%3A4000|wheels.diameter%3A1700|wheels.diameter_expl%3A35000|tires.size_convention%3A0|tires.section_width%3A20500|tires.aspect_ratio%3A5500|tires.diameter_expl%3A50000|tires.width_expl%3A7620|tires.compression%3A500}%26rear{frame.susp_type%3A0|frame.bottom_y%3A9200|frame.center_to_upper_mount_x%3A28500|frame.bottom_to_upper_mount_y%3A24000|frame.center_to_lower_mount_x%3A17000|frame.bottom_to_lower_mount_y%3A2400|control_arms.upper_length%3A24800|control_arms.lower_length%3A37500|knuckles.hub_to_upper_x%3A15000|knuckles.hub_to_lower_x%3A13000|knuckles.hub_to_lower_y%3A13000|knuckles.hub_to_upper_y%3A13000|knuckles.hub_to_strut_axis%3A14000|knuckles.strut_incl%3A8000|steering.active%3A0|steering.hub_to_outer_tie_rod_x%3A7620|steering.hub_to_outer_tie_rod_y%3A7620|wheels.offset%3A4000|wheels.diameter%3A1500|wheels.diameter_expl%3A35000|tires.size_convention%3A0|tires.section_width%3A19500|tires.aspect_ratio%3A4500|tires.diameter_expl%3A50000|tires.width_expl%3A7620|tires.compression%3A0}%26pref{diag1.px_per_mm%3A200|diag1.front_or_rear%3Afront|tab.active%3A0|units%3A1|show.f%3A1|show.ca%3A1|show.k%3A1|show.st%3A1|show.stl%3A1|show.w%3A1|show.t%3A1|show.rc%3A1|show.rcl%3A1|show.ic%3A1|show.icl%3A1|show.fvsa%3A0|show.tl%3A1|show.kpil%3A1|redraw_during_drag%3A1|chart.x_axis_center%3A0|chart.x_axis_window%3A10|chart.x_axis_num_steps%3A21|chart.x_axis_field%3Atrim.body_roll_angle|chart.y_axis_fields%3A[FR].general.roll_center.y}
