Åtdragningsmoment ramlager
Marcus C
Ibland så har Biblioteken Haynes reparationsböcker.
Vilka år gångar satt blacktoppen och model m.m så kan jag kolla upp åt dig.
Har du motorkod t.ex. RKA L1F eller liknande?
Edited by Thomas
Hittade detta på nätet
Black Top Zetec Torque Settings
Source of info. http://forums.focaljet.com/zetec-tuning ... ngine.html
Hose clamps 35 inch lbs.
Intake manifold studs 44 inch lbs.
Intake manifold bolts and nuts 13 ft. lbs.
EGR tube assembly to EGR valve 30 ft. lbs.
EGR pipe to ignition coil bracket 53 inch lbs.
EGR tube assembly to catalyst 30 ft. lbs.
Heat shield to exhaust manifold 89 inch lbs.
Exhaust manifold studs 44 inch lbs.
Exhaust manifold nuts 12 ft. lbs.
Catalytic converter to exhaust manifold 35 ft. lbs.
Catalytic converter to exhaust 35 ft. lbs.
Right-hand driveshaft center bearing 18 ft. lbs.
Generator to bracket 18 ft. lbs.
Generator bracket to upper cylinder block bolts 18 ft. lbs.
Generator bracket to lower cylinder block bolts 48 ft. lbs.
Transmission flange bolts 35 ft. lbs.
Starter motor to transmission 26 ft. lbs.
Oil drain plug, MTX transmission 33 ft. lbs.
Oil control plug, MTX transmission 33 ft. lbs.
Flywheel bolts 83 ft. lbs.
Clutch pressure plate 21 ft. lbs.
Engine roll restrictor to transmission 35 ft. lbs.
Engine roll restrictor to subframe 35 ft. lbs.
Engine rear mount to body 35 ft. lbs.
Engine rear mount (nut on transmission mounting bracket) 98 ft. lbs.
Engine front mount to engine 59 ft. lbs.
Engine front mount to body 35 ft. lbs.
Power steering pump to bracket 18 ft. lbs.
Power steering pump bracket 35 ft. lbs.
Spark plugs 11 ft. lbs.
Timing belt tensioner 18 ft. lbs.
Camshaft timing belt pulleys 50 ft. lbs.
Upper timing belt cover 89 inch lbs.
Ignition coil (El) bracket to cylinder head 15 ft. lbs.
Thermostat housing 15 ft. lbs.
Fuel rail 89 inch lbs.
Engine rear lifting eye 12 ft. lbs.
Engine rear lifting eye studs 53 inch lbs.
Engine front lifting eye 35 ft. lbs.
Engine oil drain plug 18 ft. lbs.
Oil pressure switch 20 ft. lbs.
Cylinder block oil gallery blanking plugs 17 ft. lbs.
Heater pipe bracket to oil pan 89 inch lbs.
Coolant pump 13 ft. lbs.
Crankshaft rear oil seal carrier 15 ft. lbs.
Drive belt idler pulley 30 ft. lbs.
Crankcase ventilation pipe bracket 17 ft. lbs.
Crankcase ventilation 89 inch lbs.
Coolant pump pulley 18 ft. lbs.
Crankshaft belt pulley 85 ft. lbs.
Crankshaft position sensor bracket 15 ft. lbs.
Crankshaft position sensor to bracket 71 inch lbs.
Idler pulley 17 ft. lbs.
Knock sensor 15 ft. lbs.
CYCLINDER HEAD BOLTS
Stage 1: 20 Nm
Stage 2: 40 Nm
Stage 3: 90 degrees
CAMSHAFT BOLTS
Stage 1: 10 Nm
Stage 2: 19 Nm
SUMP
Stage 1: 6 Nm
Stage 2: 10 Nm
BEARING BOLTS / CONROD BOLTS
Stage 1: 25 Nm
Stage 2: 60 degrees
CRANK BOLTS
Stage 1: 35 Nm
Stage 2: 90 degrees
Total 85Nm
Tack för snabba svar!
Nu slipper jag stå still ikväll!
/Marcus
Stage 1: 20 Nm
Stage 2: 40 Nm
Stage 3: 90 degrees
CAMSHAFT BOLTS
Stage 1: 10 Nm
Stage 2: 19 Nm
SUMP
Stage 1: 6 Nm
Stage 2: 10 Nm
Stage 1: 25 Nm
Stage 2: 60 degrees
CRANK BOLTS
Stage 1: 35 Nm
Stage 2: 90 degrees
Total 85Nm
