ORIGINAL 1994 CATERHAM 2 Litre Zetec , Kent cams, twin 45 DCOE Weber - 189bhp/170lbft torque, raceline sump “Goodwood” Techcraft silencer, Webber Alpha 3D Ignition. Quaiffe 5 speed, Long First, alloy case gearbox, (100km/t) alloy bell housing Full weather gear. Ford “Live” Axle, Limited Slip Differential, new Crown wheel and pinion. New Radtec alloy race radiator, fan override switch Cross drilled front discs/DS2500 pads Stack revcounter/speedometer/odometer, LED warning lights Removable steering wheel, 10 gallon fuel tank, enlarged boot. Tall FIA bar with high level brake light or full Safety Devices roll cage. Completely rebuild 2000 – reskinned, “wigwam” front, “modern” pedal box, new engine, axle & Gbox . 1 set “Superlite” alloy wheels with 21Rs, 1 set “Weller” steel wheels with 32Rs ( nearly new tyres on both rims! ).
Pris. 160,000 sek
Carsten Howard Steffensen
Köbenhavn 0045-40627599
[email protected]
Edited by Carsten Howard
ORIGINAL CATERHAM 2 Litre Zetec, Kent cams, twin 45 DCOE Weber - 189bhp/170lbft torque, raceline sump “Goodwood” Techcraft silencer, Webber Alpha 3D Ignition. Quaiffe 5 speed, Long First, alloy case gearbox, (100km/t) alloy bell housing Full weather gear. Ford “Live” Axle, Limited Slip Differential, new Crown wheel and pinion. New Radtec alloy race radiator, fan override switch Cross drilled front discs/DS2500 pads Stack revcounter/speedometer/odometer, LED warning lights Removable steering wheel, 10 gallon fuel tank, enlarged boot. Tall FIA bar with high level brake light or full Safety Devices roll cage. Completely rebuild 2000 – reskinned, “wigwam” front, “modern” pedal box, new engine, axle & Gbox . 1 set “Superlite” alloy wheels with 21Rs, 1 set “Weller” steel wheels with 32Rs ( nearly new tyres on both rims! ).
Pris. 160,000 sek
[email protected]
FINANSKRISE? OK, Så siger vi 140.000
Carsten
