Säljer mina Smiths instrument, endast provmonterade och testade.
- Smiths Classic Mechanical Oil Pressure Gauge. Gauge reads from 0-100PSi with 90° needle sweep. 500kr
- Smiths Classic Mechanical oil temperature gauge. Reads from 40-140°Celsius with 270° needle sweep. 52mm body diameter and comes with 6ft 6 inch capillary tube with 5/8 UNF threaded bulb. 700kr
- Smiths Classic Mechanical Water Temperature Gauge. Reads from 30-120°C with 270° needle sweep. 52mm body diameter and comes with 6ft 6inch capillary tube with 5/8UNF threaded bulb on the end. 700kr
