Grantinge_gt40 Posted February 27, 2016 Posted February 27, 2016 Ny kompakt 40 Amp Generator - 1000 kr Less than 100mm diameter. Light weight - only 3Kg and simple, two bolt mounting. Main power output is via a M6 stud. Warning light and +12v terminals are 1/4" male spade. If you wish to change the pulley, the shaft diameter is 15mm. Inköpt hos hovleverantören Car Builder Solution , artikel nummer ALTE Quote
