Starhonk Posted July 10, 2017 Posted July 10, 2017 Köpte en fiffig liten ventil att sätta på avluftningen. Se info nedan! These new in-line valves are designed so that there are no standing gas losses when the vehicle is at rest. The valve will open when the fuel is drawn from the tank and will shut once the activity ceases. Should there be a pressure build-up in the tank - hot car with full tank standing in strong sunlight - the valve will open to release the excess pressure and close once the excess pressure is released. https://www.newton-equipment.com/tank-vent-valves-inline-valves.html https://www.merlinmotorsport.co.uk/p/newton-inline-breather-vent-valve-5-16-8mm-push-on-m-tpv8 Mvh Henrik Quote
Jocke4U Posted July 17, 2017 Posted July 17, 2017 Yes! Hade en liknande på min super seven fast gängad i tanken. Funkade kanonbra - luktade aldrig bränsle i garaget. Men en liten böj/ögla på slangen. https://www.merlinmotorsport.co.uk/p/roll-over-valve-1-4-x-6jic-m-trv67 Quote
