Csgt40 Posted September 30, 2009 Posted September 30, 2009 The standard original Mk I road car set up for Camber Angle* : Front 20 minutes negative. Rear 10 minutes negative. Toe-in *: Front 30 minutes toe-in Rear 20 minutes toe-toe-in (10 minutes per wheel) Castor Angle: Front 6-6 1/2 degrees (non adjustable) Rear 7-8 1/2 degrees (adjusted to give minimum toe-in in bump and rebound positions) Toe-in change: Front: Static bump-15 mins max ideal nil. Static rebound-20 mins max ideal nil. Rear: Static bump-10 mins max nil ideal. Static rebound-15 mins max nil ideal. Ride heights*: Front: 4.125" Rear: 4.375" *CAMBER,TOE-IN,RIDE HEIGHTS ALL MEASURED WITH FULL FUEL TANKS. Quote
