Någon som vet var man kan hitta en adapter, så att man kan sy ihop en alfa (2.0 TS) med en ford typ 9 låda?
Hi,
http://www.guy-croft.com/viewtopic.php?f=4&t=2931
I couldn't find where the guy bought the "GCRE convesion" he is talking about but it looks like there are good tips about this adaptation: it looks like you just have to make an adaptor plate to adapt the bell housing of the Fiat on the type 9's main body.
If you have both ends and the right clutch (RS2000 according to them), you can take the measurements yourself and have the adapter plate done by a local machine shop?
Just a thought...
Good luck!
Tjenare!
Hittat min lösning nu!
Blir en TC motor med tillhörande v-låda ( lätt och små mått samt trimvänligt)
