voucht
Everything posted by voucht
  1. Hi, I just wanted to remain you that these seat belts are still for sale. I'm leaving Sweden soon (I'm going back to France), so it would be nice if I could sell them before I leave ! Thanks ! Sylvain
  2. Links don't look to be working. I try here: http://www.carbuildersolutions.com/fr/securon-static-adjustable-seatbelt-short-stalk-buckle
  3. Hi, I'm selling a pair of new seat belts from CBS http://www.carbuilde...rt-stalk-buckle They just have been mounted once for passing Bilprovning on my Haynes Roadster. They have never been used otherwise, and of course never been in an accident! So they are like new, except unavoidable bolt marks on the mounting points. They come complete with bolts and spacers. E-marked, short stalk (150mm). I sell them half price, so you get two seat belts for the price of one : 385 kr Description in Swedish on my add on Blocket (search in Kronoberg "bildelar verktyg", then in the add, go down to item n°19) Please, check out the complete add, there a lot of other parts/tools I'm selling to have more room in my garage. Thanks, and I wish you all a beautiful summer ! 19 by Sylvain ROIG, sur Flickr
  4. Hi, Sorry I write in English, but anyone can translate with Google ;)/> Have you moved RS6 and RS3 backwards to achieve that? If you did, you should say so, so people don't think that what you shown the video is possible with a “book” specifications chassis. Or have you removed the differential flange nut in the front of the diff? I have been building my Haynes Roadster for 3-1/2 year now, spent more than 1000 hours on it so far, passed the SFRO 1st inspection, and I'm at the final stage (I'm now fitting the bodywork), so I think I know what I'm talking about, and I can share my experience. I wrote to you personally in January to explain you why, in my opinion, it is not a good idea to weld the differential brackets. You told me yourself that on the CAD simulations you've done, it was not possible to fit the diff with welded brackets without altering the back frame. In February, after my 1st SFRO inspection, I removed everything from my car in order to have the chassis painted. When I refitted the differential, I checked again if what you wanted to do is possible. I tried to fit the differential with my brackets bolted to the chassis, as if they were welded. And it is not possible at all with a book chassis, believe me. You need to bolt the brackets to the diff first, and then install the all assembly together, by being able to put the differential sidewards, as it is too long to be flipped straightly without touching BR12 and RS6. And turning it sidewards is not possible if the brackets are welded on the chassis, they will be in the way. That is the reason why theses brackets have been designed for being bolted/removable. I don't know how you managed to slide the wooden back frame over the Sierra differential, but there should be something not regular, because to me, it is impossible if you have respected the book's specifications. And in real life, you will not slide the entire chassis over the diff like you do on the video with the wooden back frame, but you will slide the diff inside the chassis from underneath, which might be another matter! I still keep on thinking it is not a good idea to weld the differential brackets to the chassis, and as I told you already, I don't even see the benefit of it. I can bet now that if you do so, you will regret it one day. But it is just my humble opinion :)/> Good luck with your build. Sylvain
  5. Hi, I just posted a topic about my SFRO1 inspection I took yesterday for my Haynes Roadster, in the SFRO section of this forum here: http://forum.locostsweden.se/index.php?showtopic=11756 Hope this could be useful to other Haynes roadster's builders. Bye. Sylvain
  6. First, again, sorry about the English, but I really can't write in Swedish yet. For those who don't know me (I can't say I'm very active on this forum), I'm French, live in Sweden, and almost 3 years ago, I have started building a Haynes Roadster (Chris Gibbs book). There is a link to my build blog in my signature, but it is not really up to date, but that can give you an idea of what I'm building. Yesterday, I've been to my first SFRO inspection, and I thought it could be interesting for other members if I shared my experience here. Well, I'm happy to say: it went pretty well in my opinion! First the inspector made me talk about my build, the construction of the chassis, the parts I fitted, their origin, the technical choices I've made. There has been also a bit of paperwork, and I think he appreciated the way I planned the car, and the fact that I could answer all his question straight away. I think, among other things, they want to know and figure out the way you are thinking, planning, etc. I gave him a 3 page memo (same as the example from page 14 and 15 of SFRO's manual), and I think it is good to do that. The memo has to be completed, as the car is not finished yet, and even though he didn't really use it for this first inspection, I think (and I have been told), that it is quite important to have one well detailed, good looking, even with pictures (hidden elements for example). Then he told me that he couldn't see any major problem with my build, and asked me to make only two small adjustments before the final inspection: - put one or two extra fitting points on the exhaust, and at least one of them has to be from underneath the exhaust (there is only one now, and the muffler is hanging from it). - reconnect the rocker-cover breather to the intake manifold or induction pipe. There is just a small breather filter now, and they don't want that, or even an oil catch tank. They want all the vapours to be recycled in the engine to be burnt. So, nothing really bad :)/>/> I guess you all know my inspector, as he is Bosse Bildoktorn. I have to say that he has been very friendly, welcoming, nice, with a good sense of humour, and it he spoke English with me very willingly even though he is absolutely not obliged to do so. So very good feelings with him, he is a nice person (and he knows his stuffs!) For those who are wondering about the shock absorbers angle, topic that has been discussed on the Haynes Roadster section of this forum, SFRO recommends not more than 20° if I remember well, and the shock absorbers on a Haynes Roadster, according to the books design have a 45° angle. My Roadster has been built according to the book specifications, so with the 45° angle, and the inspector didn't stop on it, he didn't even mention it. So I guess it is a recommendation for people who "design" their own car, but not a requirement for builders. So, if some of you are building a Haynes, and are still wondering about that, I think you shouldn't worry too much about that, and stick to the book's design. I know the JanneE hasn't had any problem with that either, he passed SFRO2, and his car has been fully approved with the book's design suspension. But yesterday was not the best day in Smaland when it comes to weather, and driving there and back, loading and unloading 2 times the Roadster on the trailer in the cold has been a real pain though, the weather was terrible (snow, wind, and slippery roads, all that at night time), but we did it! So now, the goal is to have the car finished for May or June. I'll get my body kit in 2 or 3 weeks, and now, I have time to strip off the car, send the chassis to sandblasting and powder coating, buy another engine, and finally reassemble everything together. I'll keep you posted :)/>/> I hope this post will be useful to this forum's member. Bye for now. Sylvain http://vouchtroadster.blogspot.se/ http://www.flickr.com/photos/99498333@N06/
  7. Found the guy who is making the adaptor, from the other forum. In the UK though... http://www.guy-croft.com/index.php
  8. Hi, http://www.guy-croft.com/viewtopic.php?f=4&t=2931 I couldn't find where the guy bought the "GCRE convesion" he is talking about but it looks like there are good tips about this adaptation: it looks like you just have to make an adaptor plate to adapt the bell housing of the Fiat on the type 9's main body. If you have both ends and the right clutch (RS2000 according to them), you can take the measurements yourself and have the adapter plate done by a local machine shop? Just a thought... Good luck!
  9. Hi, Sorry I just found your post today, and I have no time to reply in details. But there is one question I want to give you an answer about right now: "Why is 14" open and 9,5" closed shock absorbers recommended on the forum over the 13"/9" recommended in the book?" You have the explanation here: http://www.haynes.co.uk/forums/showthread.php?t=5820 3rd post, fom "Bonzo". I found other interesting posts about that, and you might find more answers: http://www.haynes.co.uk/forums/showthread.php?t=7246 http://www.haynes.co.uk/forums/showthread.php?p=74893#post74861 Strange you can not register to the Haynes Forum. Have you tried lately? I know they closed it for new users about one year ago because the forum had been hacked and all the threads were spammed, it was a nightmare! But now that everything is back to normal again, it should be re-open to new uses. I'll reply longer later, but now too busy before Christmas ! Good luck. Thanks. Sylvain
  10. Hello, I'm intruding in this thread. I'm building a Haynes Roadster too, in Smaland. Sorry, I'm French and I don't speak Swedish (or very bad), and I translated this thread with Google, so I might miss some things, sorry if I did and I'm repeating things that have actually already been said. I thought I could share my experience with you about this thread's topic, as I have been through already. I hope it can be useful to some of you, even though it might be a bit late :) I am a lot on the Haynes Forum (uk), and very active there. It turned out that the shock absorbers lengths advised in the book are a bit wrong. You will need ether an extension, or longer ones. There are detailed threads on the haynes forum about that. if you want, I can try to dig them out for you. There is a general agreement about what is needed on the Haynes Roadster, and that is what I bought for mine. 4 x shock absorbers 2,25'' diameter x 14'' open x 9,5'' closed. I chose “Gazshocks” Rally Design part number G140/095B12-2 if it can help. This is very important for the calculation of the ground clearance (rallyelwood, I like your CAD drawing by the way!) A good start for the spring rates and lengths is 350 lbs x 8'' front and 250 lbs x 9'' rear. Of course this can vary according to the use of the car (Road, track days, etc.) When it comes to ground clearance now, yes, 100mm front and 150mm back seems to be a good starting point too. But keep in mine that the chassis will not be the lowest point of the car. The oil sump will. As I am using a 2,0i 8v DOHC from a ford Sierra with the MT75 gearbox, the shortening possibilities are not big, and my sump is ticking out 35-40mm under the bottom rail (if I remember well), which gives ma a "theoretical" ground clearance of 60-65mm only in theory ! http://vouchtroadster.blogspot.se/2013_06_01_archive.html I think I am going to set up the ground clearance at more the 100mm in the front when the roadster is finished. When it comes to wheels now, even 14'' inch wheels don't fit the rear upright/lower wishbone bolt. I know because I have tried that not long ago (I have pictures if you want). 15'' are the only option with the book's rear suspension design. Personally I have 7x15 wheels with 195/55x15 tyres (to keep the same development as the 185/65x14 mounted on the my Sierra donor as I use the same gearbox and speedometer. Wheels' offset (ET) is 38. More than 40 seems too much to me, the wheels is going to be very much "inside the car", and it might not look good under the rear arches (big gap between the wheel and the outside edge of the rear arch). My build blog is not up to date at all (I'm very late!) but you can see recent pictures of my car on my flickr page: http://www.flickr.com/photos/99498333@N06/ Hope this will help. Thanks. Sylvain
  11. Thank you very much for your reply Gustaf. Are you the same Gustaf who ordered brake lines from me a couple of months ago? If yes, how is it going? Do they fit as you wanted? If you have some pictures of the brake lines installed on the car, I'd love to see them. Could you please send some by email? Regarding theses bellows, I wanted to find them locally, shipment cost from the UK are too high for these kind of cheap parts. It is very good to know that the Golf MK1 ones fit, thanks! I finally dug up a single bellow from an old box lying in the garage, and it fits perfectly (I actually needed to change only one of the 2 bellows). So for now it will do the job! However, if someone has a set of original Escort MK1/2 steering rack bellows for sale in Sweden, I'm still buyer :) Thank you for the reply. Best regards.
  12. Hello everybody, I'm looking for a pair of original and new bellows (kuggstångsdamask) for my Escort MKII steering rack. Any one could sell me that for a good price please? Thank you very mcuh :)/>
  13. voucht
    Parts for sale
    Hi, These parts are still for sale if anyone is interested. Thank you.
  14. Thank you very much for the reply Gustaf, very helpful. I've contacted Svea Kardan in Bromma, we'll see if they reply. Otherwise I guess I will have to order it from the UK, I've sent enquiries to 3 different companies, so we'll see... I'll post the result of my researches here when I get all the answers. Thanks again. Best regards. Sylvain
  15. Hello everyone, Sorry to post this in English in this section. Does anyone know a company in Sweden which manufactures custom propshaft, just as Bailey Morris (http://www.baileymorris.co.uk/kitcar.asp) does in the UK? My local engineering shop don't want to shorten the one I have from my donor, so I guess I'll have to buy a custom made one :(/> I live in Kronoberg, close to Växjö. I'm building a Haynes Roadster with 2.0i DOHC engine and a MT75 gearbox from a Ford Sierra 2.0i CLX 1992. Thank you very much in advance for your replies. Sylvain
  16. voucht
    Parts for sale
    This post has already been published in the "donor car" section, but I'm copying it here as these parts for sale mostly concern Haynes Roadsters. Hi, I'm living in Sweden and I'm building a Haynes Roadster. I'm selling Ford Sierra parts that can be used on Locost/Haynes Roadster or other kit cars. PLEASE CHECK MY BLOG HERE: http://vouchtroadster.blogspot.se/2012/11/parts-haynes-roadster-locost-for-sale.html There are a lot of pictures of the parts for sale and detailed descriptions. Please send me a pm if interested, or directly an email on my address: [email protected] If you speak English, you can also call me on my cellphone : 0737235664 Part for sale are: 2 Ford Sierra front uprights : 200 kr for the pair. Weight = 12kg. 1 complete Ford Sierra steering column : 200 kr. Weight = 5kg. 1 master Ford Sierra cylinder with brake fluid reservoir : 110 kr. Weight = 2 kg. 2 front Ford Sierra brake callipers : 165 kr for the pair. Weight = 6 kg. 2 Ford Escort MK1/2 track rod ends : 40 kr for the pair. Weight = 1kg. Parts for sale separately, or the whole lot for 580 kr = saving 30% Total weight : 27 kg Payment by Paypal or cash if you collect the parts. I live in Smalland, Växjö area. I'm also selling the body-shell of my Sierra donor, with a lot of Sierra parts included. Please check my blog here: http://vouchtroadster.blogspot.se/2012/11/parts-ford-sierra-for-sale.html Thank you. Regards. Sylvain
  17. I'm selling Ford Sierra parts from my donor. See the Donor area on this forum for details. Tack!
  18. voucht
    Parts for sale
    Hi, I'm living in Sweden and I'm building a Haynes Roadster. I'm selling Ford Sierra parts that can be used on Locost/Haynes Roadster or other kit cars. PLEASE CHECK MY BLOG HERE: http://vouchtroadster.blogspot.com/2012/11/parts-haynes-roadster-locost-for-sale.html There are a lot of pictures of the parts for sale and detailed descriptions. Please send me a pm if interested, or directly an email on my address: [email protected] If you speak English, you can also call me on my cellphone : 0737235664 Part for sale are: 2 Ford Sierra front uprights : 200 kr for the pair. Weight = 12kg. 1 complete Ford Sierra steering column : 200 kr. Weight = 5kg. 1 master Ford Sierra cylinder with brake fluid reservoir : 110 kr. Weight = 2 kg. 2 front Ford Sierra brake callipers : 165 kr for the pair. Weight = 6 kg. 2 Ford Escort MK1/2 track rod ends : 40 kr for the pair. Weight = 1kg. Parts for sale separately, or the whole lot for 580 kr = saving 30% Total weight : 27 kg Payment by Paypal or cash if you collect the parts. I live in Smalland, Växjö area. I'm also selling the body-shell of my Sierra donor, with a lot of Sierra parts included. Please check my blog here: http://vouchtroadster.blogspot.com/2012/11/parts-ford-sierra-for-sale.html Thank you. Regards. Sylvain
  19. Thank you Peter, Yes, JannE's solution is amazing (as his whole built!). I actually have a good idea of what I want to do, the problem for me is finding the material here in Sweden. Any suggestion about where I could find splined shafts and/or short length of thick-wall tube? Thanks. Sylvain
  20. Hello everybody, Sorry to write in English, but I think this topic has a better place here than in the foreign section, hope you guys will not take offence. I live in Sweden and I'm building a Haynes Roadster (Chris Gibbs book). I have now to extend my steering column. SFRO says to be very careful with this part of the build, and honestly, I would prefer changing the column to a long splined shaft rather than cutting the Sierra steering shaft and welding an extension tube. But anyway, I'm struggling to find supplier for ether one or the other option. As you guys are from here, you might know suppliers I don't know. Could you please let me know, if you can, who could supply me with: - 1 : a splined shaft with Ford splines pattern (9/16'' x 36 splines), custom length (about 700mm) ? or - 2 : 1m of round thick wall tube (inside diameter : 15mm, wall thickness between 3mm and 5mm, length 1m) ? My usual steel supplier (Stål och Verktyg) don't want to sell less than 6m, when I don't need even 1m, so I don't want to wast money in that. Thank you very much in advance for your help. Sylvain
  21. Thank you very much guys for the answers. I tried some junk yards, but Sierra seem to be a rare thing now. Panzer, thank you for the tip, and yes, I've tried next week the one in Åsby (and yes, they have loads of things), but unfortunately, they didn't have any Sierra parts. Perhaps I should be patient and try again later. I also made enquiries on bildelsbasen.se, but no replies so far... so I'm still buyer of one if someone has one for sale. Thanks !
  22. Hello everybody, Sorry to post a thread in English here, but I thought it would be more suitable than in the international users section (you all speak English in Sweden :-) !) For my Haynes Roadster built, I'm looking to buy a second hand Ford Sierra steering column. I mean the complete unit: from the steering wheel to the lowest joint on the steering rack, with ignition lock (and keys!), brackets, and the column axis with the joints. If anyone is selling one, please make ma price offer. Thank you very much. Best regards. Sylvain
  23. Are you kidding me Sonny ? Read his first post on this thread, and tell me if he tried to help me or just to criticize ? Where is the help here ? I just can't believe I'm the black ship now, whereas I just have been the target in the first place, and I defended myself with a bit of humour. Can't you see that ? Perhaps you think I should I have shut up ? Sorry, not in my nature. Fred is right on one thing only : it is a very bad beginning on this forum. Thank you very much for that :notworthy: ! Such a shame... But on the another hand, I got help and support from very nice people on this forum, so sorry Sonny, but I won't leave just because of you guys. Now, I'm just using my right to answer here, but as I already said twice, we should all stop that and move on.
  24. If I reply to that, it is gonna be endless, but believe me I have thousands of thing to say. But somebody has to stop first. I got the help I needed from very nice members on the forum, thank you all, and I want to close this thread so everybody can move forward.
  25. Fred, you're hopeless, and you've got a damn nerve to tell me that people will be nice with me if I'm nice with them. You should take it for yourself ! I can't believe it : you are the one who posted a bad comment in the first place, I've always been nice and thankful on my posts, I just can't stand people like you using forums not to help but to show off. Easy to play the cool guy now, and give one tip in the middle of three shits ! And you can't help yourself giving more advices : "go with the flow", "enjoy the differences", and so on. You are the one who looks not to stand the difference mate ! Someone don't make the chassis plate by itself and you give him shit like you did to me in your first reply ! Man, you should look at yourself into a mirror before telling me this kind of things. This is my last reply to your comments, its 3 to 3, and the rest will be ignored, I left kinder garden a long time ago. And as I started this thread, I ask you to do the same.
