Carsten Howard
Everything posted by Carsten Howard
  1. http://www.superseven.dk/
  2. Bud modtages Mvh Carsten
  3. Uk plader. short cokpit, byggeår er 1994. Mvh Carsten Howard Steffensen
  4. FINANSKRISE? OK, Så siger vi 140.000 Mvh Carsten
  5. ORIGINAL 1994 CATERHAM 2 Litre Zetec , Kent cams, twin 45 DCOE Weber - 189bhp/170lbft torque, raceline sump “Goodwood” Techcraft silencer, Webber Alpha 3D Ignition. Quaiffe 5 speed, Long First, alloy case gearbox, (100km/t) alloy bell housing Full weather gear. Ford “Live” Axle, Limited Slip Differential, new Crown wheel and pinion. New Radtec alloy race radiator, fan override switch Cross drilled front discs/DS2500 pads Stack revcounter/speedometer/odometer, LED warning lights Removable steering wheel, 10 gallon fuel tank, enlarged boot. Tall FIA bar with high level brake light or full Safety Devices roll cage. Completely rebuild 2000 – reskinned, “wigwam” front, “modern” pedal box, new engine, axle & Gbox . 1 set “Superlite” alloy wheels with 21Rs, 1 set “Weller” steel wheels with 32Rs ( nearly new tyres on both rims! ). Pris. 160,000 sek Carsten Howard Steffensen Köbenhavn 0045-40627599 [email protected]
  6. Ford Zetec 2,0 engine, Kent cams,twin 45 dcoe-189bhp/170lbft torque, raceline alloy.racesump, techcraft silencer, Weber 3D alpha ignition system. Complete with starter and alternator, clutch aso. Quaife 5 speed, long first, alloy case , alloy bell housing. Stack revcounter/speedometer/odometer and LED warning lights. 35000,- Danske kr. Carsten Howard Steffensen København Telf. 0045 4062 7599 eller [email protected]
